July 31, 2012, 08:30 |
layers on snappyhexmesh
Alessandro Pani
Rep Power: 13 |
I've a problem with snappyhexmesh
I've enabled layers creation, but with no changes on mesh... necessary i've done some mistakes... but i'm not able to find where they are any idea? Thanks |
July 31, 2012, 14:01 |
Eric
Rep Power: 14 |
I have only used snappyhexmesh for one mesh but I know that I had problems with the layers forming when I set nGrow to anything other than 0 but that's not the problem in this case since yours is already at 0. I would play with the feature angle. If you set it to 180 then layers should grow no matter what the angle. If this doesn't do anything then I would try increasing your tolerance's. What type of geometry are you meshing?
July 31, 2012, 16:06 |
Alessandro Pani
Rep Power: 13 |
Ok now with ngrow 0 and feature angle 180 it works well
thank you Last edited by Dr.Faustus; August 2, 2012 at 03:48. |
[snappyHexMesh] Old and busted: snappyHexMesh and add layers with edges | Siassei | OpenFOAM Meshing & Mesh Conversion | 6 | August 14, 2018 18:33 |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 09:46 |
[snappyHexMesh] 2D snappyHexMesh with layers | grjmell | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2013 12:00 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers | eti0123456789 | OpenFOAM Meshing & Mesh Conversion | 5 | April 9, 2013 02:36 |
