Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
snappyHexMesh does not snap to corner
Like Tree1Likes
  • 1 Post By SirWombat
Old   August 29, 2012, 10:58
Default snappyHexMesh does not snap to corner
Matthias
aeroMatze is on a distinguished road
Dear all,
apologies for this noob question right away, but I've been working on solving this problems for some days now and I can't come to a solution.
I try to mesh a simple rectangular nozzle and I run into problems on the intersection of the outer shape and the outlet. (--> see attached images)
Strangely enough the intersection of Inlet and outer shape is meshed just fine.
snappyHexMeshDict and blockMeshDict:
snappyHexMeshDict.txt
blockMeshDict.txt
I wonder if anyone can come up with some ideas where my mistake might be.
Thanks in advance for any input.
Matze
aeroMatze is offline   Reply With Quote
Old   August 30, 2012, 06:08
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
Try to use featureEdges. In case you did you may want to ease/alter your quality settings.
Compared to the rest of the domain your edges seem to have a very high cell resolution. If you use featureEdges you won't need to refine those as much.
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   August 30, 2012, 07:50
Matthias
Hi, thanks for the answer.
I'm using surfaceFeatureExtract, but the problem is that not all detected edges are also refined.
For illustration I have added a very simple geometry.
When I run featureExtract it finds 8 points and 12 edges. 8 edges are marked 'region', one is marked 'external', three are marked 'internal'. Maybe that's a symptom of the problem, but neither know what that implies nor how to change it...
Any more ideas? Please ignore the high resolution along the edges. I'm aware of the fact that that's not necessary, but I don't believe it is the root of my problem.
Best regards,
Matze
Old   August 30, 2012, 08:51
Jan
i see ... have you checked that all your feature edges are there?
to check using paraFoam you will have to convert the eMesh-File to an obj-File like this
  surfaceFeatureConvert /constant/triSurface/YOURFILE.eMesh  featurelines.obj
Then load the " featurelines.obj" in paraFOam and check whether the lines correspond to your edges.
Oh and by the way what version are you using? ... there were problems in 2.0.x so better head for 2.1.x ... i just saw that your files say 2.1.1. so that should be OK.
~~~_/)~~~
Old   August 30, 2012, 09:03
Matthias
I'm using OF 2.1.1 ... and yep, all 8 feature lines are visible when importing them in paraview. The eMesh file for this case is very short, so I also checked it in an editors and again: all 12 edges are there...
Old   August 30, 2012, 09:23
Jan
hmm ... too bad ...
There is this thread here, but the issue should have been resolved: SnappyHexMesh refuses to refine certain edges
If those feature-edges dont work you can edit them in Blender (www.blender.org). Try to make them longer/shorter. You can even create other feature edges in blender an export them as "obj".
when ready exporting from blender you will have to change the character "f" to an "l" for all eges in the obj-file. (migh be a german issue).
sed -i 's/f /l /' features_from_blender.obj
then convert the obj to an eMesh
surfaceFeatureConvert features_from_blender.obj constant/triSurface/features_from_blender.eMesh
I am using that method quite frequently as for a lot of geometries that i use (mainly ship hulls) i get a lot of feature lines that I don't want. So I delete those unwanted lines using blender. Works quite nicely
G Jan
Thom likes this.
~~~_/)~~~
Old   January 26, 2013, 12:37
sda
sda is on a distinguished road
Mattias,
Did you ever solve your edge resolution problem?
Saif
sda is offline   Reply With Quote
Old   June 24, 2013, 04:44
Thomas Smyth
Thom is on a distinguished road
Thank you very much for that advice. Been banging my head (literally at times) against a wall all day trying find what the problem was!
Thom is offline   Reply With Quote
corners, edges, snappyhexmesh
Thread Tools
Trackbacks are On
snappyHexMesh doesnt snap staustrahltriebwerk OpenFOAM Native Meshers: snappyHexMesh and Others 43 July 25, 2015 15:04
snappyHexMesh does not snap everywhere flowris OpenFOAM Native Meshers: snappyHexMesh and Others 6 June 11, 2013 10:47
snappyHexMesh failing to snap ("did not find surface within...") Jaworski.Mike OpenFOAM Native Meshers: snappyHexMesh and Others 6 May 27, 2013 08:43
Specify snappyHexMesh edges to snap mturcios777 OpenFOAM 0 August 18, 2011 14:49
snappyHexMesh does not snap beto OpenFOAM Native Meshers: snappyHexMesh and Others 7 April 19, 2010 11:51
