[snappyHexMesh] troubles with sHM and parallel
Old   August 30, 2012, 17:00
Default troubles with sHM and parallel
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey guys,
I am using sHM since 1 year and since last week I get the following error by executing sHM parallel:
Create mesh for time = 1
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] read failed
[1]
[1]     From function UIPstream::UIPstream(const commsTypes, const int, DynamicList<char>&, streamFormat, versionNumber)
[1]     in file UIPread.C at line 114.
[1]
FOAM parallel run aborting
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] read failed
[2]
[2]     From function UIPstream::UIPstream(const commsTypes, const int, DynamicList<char>&, streamFormat, versionNumber)
[2]     in file UIPread.C at line 114.
[2]
[2]
Read mesh in = 0.12 s
[2] #0  [1] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1  Foam::error::abort() in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::error::abort() in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2  Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2  Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so"
[1] #3  Foam::IPstream::IPstream(Foam::UPstream::commsTypes, int, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so"
[2] #3  Foam::IPstream::IPstream(Foam::UPstream::commsTypes, int, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4  Foam::IOdictionary::readFile(bool) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #4  Foam::IOdictionary::readFile(bool) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #5  Foam::IOdictionary::IOdictionary(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #5  Foam::IOdictionary::IOdictionary(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #6  Foam::solution::solution(Foam::objectRegistry const&, Foam::fileName const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #6  Foam::solution::solution(Foam::objectRegistry const&, Foam::fileName const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #7  Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #7  Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[1] #8   in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[2] #8
[1]  in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh"
[1] #9  __libc_start_main[2]  in "/home/shorty/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/snappyHexMesh"
[2] #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #10   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #10
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 1 with PID 13823 on
node cfd exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[cfd:13821] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[cfd:13821] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I compiled a other sHM - version. but removed it again. is it possible that I destroyed my 2.1.x version of sHM?
Or whats the error?
Thanks for reading and helping
PS: Running solvers in parallel mode is working fine as well
Tobi
Tobi is offline   Reply With Quote
Old   August 30, 2012, 17:54
Tobi's Avatar
Tobias Holzmann
Okay it seems that there is more destroyed - I ll recompile OF.
[snappyHexMesh] Parallel sHM error vigges OpenFOAM Meshing & Mesh Conversion 12 September 23, 2022 01:23
[snappyHexMesh] Problem with boundaries with sHM in parallel running Loekatoni OpenFOAM Meshing & Mesh Conversion 0 January 24, 2019 07:56
[snappyHexMesh] OpenFoam in parallel with sHM and sFE pradyumnsingh OpenFOAM Meshing & Mesh Conversion 4 October 26, 2018 16:25
[snappyHexMesh] SHM parallel error. I honestly have no idea stark22 OpenFOAM Meshing & Mesh Conversion 4 December 13, 2017 00:42
[snappyHexMesh] shm in parallel with simple decomposition mihaipruna OpenFOAM Meshing & Mesh Conversion 6 July 16, 2015 04:55
