[Commercial meshers] createBaffles for fluent3DMeshToFoam |
October 5, 2013, 10:26 |
Mohsen KiaMansouri
Rep Power: 16 |
Dear Foamers
I want to define an interior plane inside my domain for my inlet boundary condition (for using mappedVelocityFlux B.C. we need an interior patch). I searched the whole forums and found that there is no such a concept in OpenFOAM. one way is to create a cyclic baffle (createBaffles). I've also studied all the posts regarding createBaffles and also all the tutorials in openFoam: Code:
find $FOAM_TUTORIALS -name Allrun | xargs grep -sl createBaffles Code:
/opt/openfoam211/tutorials/heatTransfer/buoyantSimpleFoam/circuitBoardCooling/Allrun /opt/openfoam211/tutorials/incompressible/pimpleFoam/TJunctionFan/Allrun /opt/openfoam211/tutorials/lagrangian/porousExplicitSourceReactingParcelFoam/filter/Allrun /opt/openfoam211/tutorials/multiphase/interFoam/ras/damBreakPorousBaffle/Allrun Code:
createBaffles [OPTIONS] <faceZone> <(masterPatch slavePatch)> But I generated my mesh in Gambit so I can not define the required boxes that are needed by topoSetDict. I defined an interior plane in Gambit. then export it to OpenFOAM using fluent3DMeshToFoam. the interior plane converted to faceZone automatically. so I have a faceZone that is needed for createBaffles. I also need 2 cyclic patches too. I added them manually into my boundary Code:
type cyclic; nFaces 0; startFace ???; is there any simpler method for creating a cyclic baffle using Gambit? can this cyclic baffle be created in Gambit and then be exported to OpenFOAM? Any help will be appreciated.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
October 6, 2013, 12:50 |
Mohsen KiaMansouri
Rep Power: 16 |
I've found that if we manually add two cyclic patches with nFaces=0 into the boundary of polyMesh just like in TJunctionFan:(a cyclic baffle for fan b.c.)
fan_half0 { type cyclic; nFaces 0; startFace 10125; matchTolerance 0.0001; neighbourPatch fan_half1; } fan_half1 { type cyclic; nFaces 0; startFace 10125; matchTolerance 0.0001; neighbourPatch fan_half0; } I meshed my Geometry in Gambit so I don't have a blockMeshDict. If I only add the above lines into my boundary without blockMesh , The CheckMesh Gives Error What can I do??
August 14, 2015, 05:02 |
Rep Power: 13 |
Hey,
i am faceing a similar problem at the moment! Did u find a solution to this? Or to other users, can u give a hint. I imported an external mesh and want to create baffles from faces. How can one do that? thx!! |
Display Modes | |
Problem with createBaffles - want to make master and slave internal patches | artymk4 | OpenFOAM | 1 | May 22, 2021 05:45 |
CreateBaffles on open/closed models | wouterremmerie | OpenFOAM Post-Processing | 1 | June 18, 2018 05:38 |
Problems using createBaffles to create a 3D thermal baffle | zfaraday | OpenFOAM Running, Solving & CFD | 10 | September 6, 2017 17:07 |
Is there a bug when running createBaffles in parallel??? | zfaraday | OpenFOAM Pre-Processing | 1 | May 12, 2015 13:32 |
Error in using createBaffles | lakeat | OpenFOAM Bugs | 22 | June 14, 2010 03:31 |
