[Gmsh] syntax error in opening *geo file in gmsh
Old   September 14, 2012, 01:21
Default syntax error in opening *geo file in gmsh
summer
summer8 is on a distinguished road
hi there,
i am intending to export a *geo file containing geometry with solid meshing from solidworks to gmsh. however, gmsh reports syntax error (*) in line 1 of the file and doesn't open. what does this mean? could anyone please kindly let me know what exactly is the problem here?
thank you!
summer8 is offline   Reply With Quote
Old   September 14, 2012, 22:22
Jason Eason
JulytoNovember is on a distinguished road
The .geo file for Solidworks has a different format than Gmsh, from what I see. Open your file in a file editor, and do the same with a Gmsh .geo file and you will see the difference. Export your file as a .step or .brep file, then load it into Gmsh and see if that helps.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   September 16, 2012, 15:49
summer
but if i were to save it as a STEP file in solidworks and export to gmsh, i would only be left with the surface geometry and i would have to mesh again in gmsh, wouldn't i?
I was wondering whether there is any way that i can retain the mesh from solidworks in gmsh and then be able to export it as a *msh file for FE pre-processer. Is it possible?
Thank you for your time and reply!
Old   September 20, 2012, 23:10
Jason Eason
Try .stl format, that way your file is still a mesh. Import the .stl file into Gmsh, then save the file in the .msh format. I've never used Solidworks, but I'm guessing .geo file for Solidworks is a mesh. However; .geo file for Gmsh is a geometry. I wonder can Solidworks read Gmsh .geo file, do you know?
geo file, gmsh, syntax error
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
