Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
A DMZ for snappyHexMesh
Like Tree2Likes
  • 1 Post By SirWombat
Old   September 19, 2012, 20:19
Default A DMZ for snappyHexMesh
Conn Clark
ConnClark is on a distinguished road
I have been meshing with some large meshes (at least for my laptop) and have about 6GB of data swapped out before snappyHexMesh starts eliminated mesh cells that are in enclosed surfaces. Is there a way to designate a Don't Mesh Zone to tell sHM not to bother with refining or meshing in volume before it gets to the point of eliminating cells in an enclosed surface? (if not it would be a nice feature to save time meshing )
Thank You
Conn
ConnClark is offline   Reply With Quote
Old   September 20, 2012, 04:23
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
Here's an idea: you could use a "coarse" snappyHexMeshDict with a smaller surface than the original one. Then use your "fine" snappyHexMeshDict on that mesh. This will only work, if all of the "fine" surfaces is still inside a mesh region. Otherwise snappy won't snap at all.
ConnClark likes this.
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   September 20, 2012, 04:29
Jan
just tried it with my setup, 'cause I really like the idea of saving memory and time!!
for the coarse mesh (snappyHexMeshDict_coarse):
castellatedMesh true;
snap            false;
addLayers       false;
then turn all your surface refinements to "0" and delete all refinementRegions.
for the fine mesh (snappyHexMeshDict_fine):
just take you original snappyHexMeshDict.
I used the following script "fastermesh.sh"
#!/bin/sh
cp system/snappyHexMeshDict_coarse system/snappyHexMeshDict
blockMesh
snappyHexMesh -overwrite
cp system/snappyHexMeshDict_fine system/snappyHexMeshDict
Seems to work very well in my case.
Greetings,
Jan
~~~_/)~~~
Old   September 20, 2012, 18:56
Conn Clark
Thank You, That helped a lot!!
Conn
Old   September 21, 2012, 12:58
Conn Clark
Oops,
I spoke too soon. After looking at the simulation data something wasn't right. The Mercedes I was simulating has been turned into a rice-boy neo-cubist car. The coefficient of lift is an impressive value of 1.4 . I don't think anybody has achieved that in auto design before.
back to swapping to disk.
Thread Tools
Trackbacks are On
