[Other] How to convert a mesh into openfoam format
Old   September 30, 2012, 23:53
Smile How to convert a mesh into openfoam format
Reno
jr33 is on a distinguished road
Hi foamers,
I have a following triangular meshes for a 3d geometry ( stl format).
https://dl.dropbox.com/u/68983831/Y-...sh_picture.png
so far I am using gmsh, I am trying to figure out:
How to convert above mesh ( .stl and .msh formats) into openfoam format:
If I use: gmshToFoam new.msh
--> FOAM FATAL IO ERROR:
No cells read from file "new.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
file: new.msh at line 4995.
From function readCells(..)
in file gmshToFoam.C at line 721.
FOAM exiting
How to fix above error.
is there any interactive or alternative software that I can use to convert a mesh into foam format i.e. into blockMeshDict.
thanks
jay
jr33 is offline   Reply With Quote
Old   October 2, 2012, 17:20
Retired Super Moderator
Bruno Santos
Greetings Jay,
I think the problem you're having is due to a simple reason: you have a 3D surface mesh, not a 3D volume mesh.
This is why you're unable to convert the mesh directly to OpenFOAM, because OpenFOAM works with 3D volume meshes.
You either finish generating the mesh:
Best regards,
Bruno
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[Technical] How to convert Corner-grid format to OpenFOAM mesh ELwardi OpenFOAM Meshing & Mesh Conversion 0 April 20, 2019 12:05
[Other] how to convert a mesh drawn in matlab to a format which can be used in OpenFOAM jali OpenFOAM Meshing & Mesh Conversion 3 July 19, 2017 20:16
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[Other] Mesh Conversion: OpenFoam (polyMesh format) to Calculix gillers18 OpenFOAM Meshing & Mesh Conversion 2 April 24, 2015 03:37
