[Sponsors] | |||||
Rep Power: 3 ![]() |
Hello All,
I have created a pipe geometry with a zero-thickness baffle at the centerline for a portion of the pipe. I also export the pipe wall, inlet, and outlet as well as the battle to a .stl file. When I try to create the feature edge mesh, I'm told that it only works for closed geometry. If I go ahead and run SHM, I'm told that my .stl is not searchable and I get no mesh. I think my problem has to do with the fact that the opposite sides of the baffle don't point into the domain. Has anyone encountered this problem and know of a fix? Any help would be very much appreciated. Regards, Timbojones |
Bruno Santos
Rep Power: 45 ![]() ![]() |
Greetings Timbojones,
AFAIK, you have define in "snappyHexMeshDict" to mesh using multiple zones. Because the baffle you're trying to create using an STL implies that the mesh will have two independent sections! After the mesh is complete, you can use createBaffles, if I'm not mistaken. Best regards, Bruno
A very nice procedure for setting up SHM for this case can be found here.
handling of baffle regions or surfaces with zero thickness with snappyHexMesh I've tried it for my case and it works well for defining a basic mesh. My next difficulty comes when I want to add layers to the baffle. Simply adding layers for the refinement surface prior to running createBaffles will not introduce the near-baffle layering in the mesh. Running SHM with layering only after creating the battle won't do the job either. What am I still missing here? I really appreciate all the help I've gotten from the forum. Thanks to all. |
#4 | |
Sha Huang
Rep Power: 2 ![]() |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Native Meshers: snappyHexMesh and Others | 9 | November 2, 2011 03:50 |
| Mesh motion with Translation & Rotation | Doginal | CFX | 0 | August 3, 2011 16:37 |
| Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
| Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
| unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
