[snappyHexMesh] Baffle from Blender .stl won't mesh with SHM
Like Tree1Likes
  • 1 Post By timbojones
Old   October 12, 2012, 01:59
Default Baffle from Blender .stl won't mesh with SHM
timbojones is on a distinguished road
Hello All,
I have created a pipe geometry with a zero-thickness baffle at the centerline for a portion of the pipe. I also export the pipe wall, inlet, and outlet as well as the battle to a .stl file. When I try to create the feature edge mesh, I'm told that it only works for closed geometry. If I go ahead and run SHM, I'm told that my .stl is not searchable and I get no mesh.
I think my problem has to do with the fact that the opposite sides of the baffle don't point into the domain. Has anyone encountered this problem and know of a fix? Any help would be very much appreciated.
Regards,
Timbojones
timbojones is offline   Reply With Quote
Old   October 13, 2012, 05:14
Retired Super Moderator
Bruno Santos
Greetings Timbojones,
AFAIK, you have define in "snappyHexMeshDict" to mesh using multiple zones. Because the baffle you're trying to create using an STL implies that the mesh will have two independent sections!
After the mesh is complete, you can use createBaffles, if I'm not mistaken.
Best regards,
Bruno
Old   October 17, 2012, 23:57
A very nice procedure for setting up SHM for this case can be found here.
http://www.cfd-online.com/Forums/ope...pyhexmesh.html
I've tried it for my case and it works well for defining a basic mesh. My next difficulty comes when I want to add layers to the baffle. Simply adding layers for the refinement surface prior to running createBaffles will not introduce the near-baffle layering in the mesh. Running SHM with layering only after creating the battle won't do the job either. What am I still missing here? I really appreciate all the help I've gotten from the forum.
Thanks to all.
wyldckat likes this.
Old   January 9, 2013, 10:48
Sha Huang
Joanna Huang is on a distinguished road
Originally Posted by timbojones View Post
Hello All,
Regards,
Timbojones
Hello, can you please tell me how to exprot the boundary specification into a . stl file, what kind of software are you using, thank you so much for that
Joanna Huang is offline   Reply With Quote
[snappyHexMesh] Retaining mesh inside and outside of the region occupied by .stl file pvpnrao OpenFOAM Meshing & Mesh Conversion 3 April 28, 2017 19:13
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] Problems with multi-region mesh in sHM Artur OpenFOAM Meshing & Mesh Conversion 0 July 16, 2013 08:52
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 06:07
