Two different layer thicknesses with same settings
Hello Foamers,
I meshed a case with layers today: Code:
castellated true; Code:
The output therefor is: Code:
The question - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Why is snappyHexMesh calculating two different thicknesses with the same settings? Can someone give me an advice? Thanks in advance Tobi |
Hi all,
the problem is caused by salome. The UNV mesh is destroyed or something like that if you export it and convert it into a foam mesh. There are some problems with unused points. After building the same backgroundmesh in a other way. It works now. Solved! |
