Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Surface Meshes Merged in SnappyHexMesh (Pictures Inlcuded)
Old   December 3, 2012, 05:33
Default Surface Meshes Merged in SnappyHexMesh (Pictures Inlcuded)
sda
sda is on a distinguished road
Dear OpeFOAMers,
I am working on a mesh of a generic car body using SnappyHexMesh. There is a region where the surface mesh on two tyres merges witht the wheel wheel of the car body itself.
I am reasonably certain that the .STL file is of good quality so I don't think the geometry is the problem.
I am steadily working my way through the meshing parameters to see which one will effect and improvement but I was hoping to reach that goal sooner with a tip from one of you.
I have included pictures.
Thanks for any suggestions.
Regards,
Saif
sda is offline   Reply With Quote
Old   December 3, 2012, 09:08
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
the problem is that you just have one cell between the tyre and the body and sHM doesn't know how to solve it. increase your mesh resolution in that area to have at least 3 cells between the two surfaces and the issue will disappear. although to have good results you'll probably need more than that---
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   December 3, 2012, 09:22
sda
Vieri,
Thanks for your reply. Do I simply increase the refinement on the surfaces or do I increase the values for any of the following parameters below
nCellsBetweenLevels 3;
tolerance 4.0; // under the snapControls
Thanks.
Saif
Old   December 3, 2012, 13:01
sda
Vieri,
Your suggestion was useful but not in the way I expected. I checked the geometry because of your comment and found that a designer had actually moved the wheel. It was touching the wheel arch surface.
After I moved the wheel to the correct position it meshes fine now.
Thanks all the same.
Regards,
Saïf
snappyhexmesh 3d, surface mesh merged
Thread Tools
Trackbacks are On
snappyHexMesh: problem meshing baffle (surface with zero thickness) julien.decharentenay OpenFOAM Native Meshers: snappyHexMesh and Others 7 June 16, 2012 08:12
Do Merged Patch Pairs require identical (conformal) meshes? delic OpenFOAM 1 April 19, 2010 08:05
Differents Meshes for an unique surface Tati CFX 9 December 8, 2009 11:36
Mesh generation from dirty surface meshes bastil OpenFOAM Meshing Format & General Technical 9 December 10, 2007 11:17
Empty surface in sliding meshes. Pierre Ricco FLUENT 2 March 14, 2001 16:01
