[blockMesh] how to get the (x,y,z) coordinate of the cells created by blockMesh |
April 19, 2013, 17:35 |
Rep Power: 13 |
When we use blockMesh to create the mesh, the mesh files such as 'boundaries', 'faces', 'neighbours', 'owners', 'points' will be generated. Just wondering how could I determine the coordinates of each cell based on those files? Many thanks in advance! Sophie |
April 20, 2013, 04:20 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Sophie,
You can directly use the utility Code:
writeCellCentres -time 0 Kind regards Niels |
April 20, 2013, 06:19 |
Rep Power: 13 |
Hi Niels,
Thank you so much! It's fantastic! best wishes, Sophie |
blockmesh, cell centre, cells, points |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 | Isaac Manohar Ch. | FLUENT | 1 | June 2, 2000 04:58 |
