Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Water burst inside snappyHexMesh
Old   December 5, 2012, 11:09
Default Water burst inside snappyHexMesh
Efstratios Mavrogiannis
raysark is on a distinguished road
i am a begineer in OpenFoam.
I created an stl file representing three connected tubes and this is my snappyHexMesh.
I want to find a way to add a water box inside me snappyHexMesh that bursts like the damBreak case.
Do you know what do I have to write and where (e.g. snappyHexMeshDict)?
Thank you
File Type: jpg Screenshot from 2012-12-05 14:11:16.jpg (61.0 KB, 16 views)
raysark is offline   Reply With Quote
Old   December 5, 2012, 13:34
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The damBreak case uses setFields to define a region where the fluid is located (two-phase flow). If this is all you want, then you don't need to do anything in snappyHexMesh, just use setFields. If you want actual patches you can set conditions on (split the domain into an inside/outside), you'll need to refer to the pimpleDyMFoam propeller tutorial case. They create an internal cylinder to use as an AMI boundary; you could use the same approach.
mturcios777 is offline   Reply With Quote
Old   December 5, 2012, 13:53
I tried to use setFields but I couldn't do it. At the beginning I set a boxToCell with water in the Mesh but of course disappeared when I executed snappyHexMesh. Do you know which box "command" to use in order to keep it in after the snappyHexMesh. Probably I need a box that it is not connected to any of the faces of the blockMesh so i can locate it in the place where the snappyHexMesh appears and with locationInMesh to keep. Sorry if too complicated and thank you for the pimpleDyMFoam case I will see it
Old   December 5, 2012, 13:55
Marco A. Turcios
You have to use setFields after snappyHexMesh.
Old   December 5, 2012, 14:34
I set the locationInMesh so both the blockMesh and the snappyHexMesh can be seen and I used setFields after the snapyHexMesh. everything was ok until I pressed play and no volume field for water was available in the Mesh only the blockMesh and the snappyHexMesh
Old   December 5, 2012, 14:49
Marco A. Turcios
After you have created your domain with snappyHexMesh, you can then run setFields on the newly created domain. Make sure that the settings in system/controlDict have your start time to be the mesh created by sHM. Are you using the overwrite function for sHM, or are you keeping the intermediate meshes?
Thread Tools
Trackbacks are On
Inside and outside mesh with snappyhexmesh nzy102 OpenFOAM Native Meshers: snappyHexMesh and Others 21 February 16, 2016 17:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
