Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
scotch error on motorbike on 16p
Like Tree1Likes
  • 1 Post By dkokron
Old   December 24, 2012, 21:53
Default scotch error on motorbike on 16p
Dan Kokron
dkokron is on a distinguished road
All,
I received the following error from scotch-5.1.11 when running snappyHexMesh using 16 processors on the incompressible/pisoFoam/les/motorBike tutorial. The 8p case ran fine out-of-the-box.
"dgraphFoldComm: internal error (3)"
This error emanates from line 307 of ThirdParty-2.1.x/scotch_5.1.11/src/libscotch/dgraph_fold_comm.c
I reviewed the code from newer versions of scotch and found significant changes between 5.1.11 and 5.1.12 for this same file. I installed scotch-5.1.12b and sure enough, snappyHexMesh ran fine on 16p. I reran the 8p case to see if the new scotch changes the results significantly. The mesh started to diverge after a few iterations, but the final drag coefficients agreed within the first decimal place. Close enough for me.
I also tried the scotch-6.0.0 release, but snappyHexMesh failed at run time with an unresolved symbol.
Hope this helps.
Dan
wyldckat likes this.
dkokron is offline   Reply With Quote
Old   December 27, 2012, 07:01
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Dan and welcome to the forum!
Many thanks for sharing this information! Now I understand better why this bug report was made a year ago: http://www.openfoam.org/mantisbt/view.php?id=355
Hopefully in the next major release of OpenFOAM, they'll update the Scotch library version.
Best regards,
Bruno
Thread Tools
Trackbacks are On
Trying to understand the motorBike tutorial Andyjoe OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 10, 2014 16:57
Editing the motorBike case, loading diffirent .stl btgyd OpenFOAM Native Meshers: snappyHexMesh and Others 1 September 26, 2011 17:24
decomposePar with scotch exits with : ERROR: graphCheck: duplicate arc ancsa OpenFOAM 3 July 11, 2011 05:02
Problem with Scotch in 1.7.x? dancfd OpenFOAM Running, Solving & CFD 0 June 15, 2011 21:52
motorBike tutorial and Scaling - New geometry used, scaled and now large velocity!!! scott OpenFOAM 1 July 29, 2010 04:09
