January 9, 2013, 08:35 |
Snappy mesh- stl file
Sha Huang
Rep Power: 13 |
Hello, I am now doing some simulation on train aerodynamics. The geomety of the train is very complex, and i have to specify the train boggie section, head coach. middle coach and end coach separately. I wonder how can I specify them and how can I transfer the geomety into stl fomate.
January 14, 2013, 13:00 |
Markus Rehm
Rep Power: 17 |
Hi Joanna,
consider using Blender for your stl-generation. Then you could also use the swiftSnap tool. Which format do you have right now? It is possible to define different mesh zones. You could generate the different meshes separately and then stitch them together. However, there are plenty of other possibilites and programs. Markus |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
