[snappyHexMesh] Bulky edges using snappyhexmesh |
February 11, 2013, 09:38 |
Ingri Løvaas
I'm having troubles getting the edges properly meshed using snappyHexMesh. The geometry is modelled using blender, where SnappyHexMeshDict and .stl files are generated through swiftsnap-addon in blender. As seen from the attached images the edges wont snap properly and the surface is bulky near the edges. I have tried alternative settings for the snapcontrol entries and disabled some of the MeshQualityControl as the minTetQuality (set to 0.5), but then the checkMesh fails. I would be really happy if anyone could help or leave some comments on what might be wrong. I have attached files for running snappyHexMesh. Thanks, Pin |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
