Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
problem with adding layer in SHM
Like Tree2Likes
Old   May 28, 2013, 12:58
s.m
saeideh mohamadi
s.m is on a distinguished road
Originally Posted by Haces View Post
If you set restrictive parameters in the quality controls the quality of the mesh will be better but it will create more problems during the snapping
hi david,
what do you mean with "restrictive parameters" ?
i don't understand your meaning.
s.m is offline   Reply With Quote
Old   May 29, 2013, 17:04
David Haces
Haces is on a distinguished road
Hi s.m
With the meshQualityControls you can choose the final quality of the mesh. If you set this quality controls to produce a high quality mesh, probably snappy may not snap correctly to the surface or create 100% of the layers. If you relax this parameters probably the layer addition will work better but, in return, you will create a mesh with lower quality.
David
s.m likes this.
Haces is offline   Reply With Quote
Thread Tools
Trackbacks are On
Fail to create boundary layers during sHM farahiam OpenFOAM Native Meshers: snappyHexMesh and Others 13 October 15, 2014 19:46
Mixed Convection Turbulent Boundary Layer Problem deji OpenFOAM 14 May 29, 2014 09:51
Problem with snappyHexMesh samiam1000 OpenFOAM 2 December 13, 2012 09:41
Flat plate boundary layer problem student Main CFD Forum 3 May 21, 2007 13:10
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
