Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
orthogonality problem with raw STL file
Old   April 15, 2013, 11:53
Default orthogonality problem with raw STL file
Debb
tellico is on a distinguished road
I've been trying to use snappy on an (ascii) stl file that was created by scanning a hallway.
After running snappyHexMesh I get a lot of orthogonality issues, and I'm unable to run simpleFoam on the generated mesh.
I'm pretty sure the issue is with the raw stl file, but I'm not sure what the stl criteria should be.
Any advice on what I can do to the raw stl data to avoid these issues?
I've attached a screen shot of the raw stl data in paraView.
tellico is offline   Reply With Quote
Old   April 16, 2013, 03:18
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Have you run the surfaceCheck utility on the file? What does that report?
Visually where is the mesh bad? You can subset the bad cells and faces to view in paraview.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Thread Tools
Trackbacks are On
Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Native Meshers: snappyHexMesh and Others 9 April 7, 2012 08:50
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
