[blockMesh] two sided mesh refinement(in both direction)
Like Tree2Likes
  • 1 Post By colinB
  • 1 Post By Yosmcer
Old   May 23, 2013, 06:43
Default two sided mesh refinement(in both direction)
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
I wondering if is there a way to have a mesh grow/decrease ratio in both sides of a block without the need to break it to two blocks.
in the customary way it has ratio only in one direction
hex (1 2 5 4 10 11 14 13) (100 10 1) simpleGrading (.5 8 1)
is there a feature to refine mesh with a ratio in both directions like FLUENT and maybe other softwares?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 23, 2013, 10:40
colinB is on a distinguished road
the keyword is doubleGrading see below:
http://www.cfd-online.com/Forums/ope...e-grading.html
be prepared it is a do-it-yourself feature of OF
regards
immortality likes this.
colinB is offline   Reply With Quote
Old   May 24, 2013, 03:54
Yosmcer Mocktai
Yosmcer will become famous soon enough
The other grading method in the tutorial is edgeGrading but it only allow to decompose according to the edges instead of only direction. This do not allow to have different direction of grading on the same edge.
So the solution seams to be to use this king of script. However, I's possible that you need to update it to be compatible with your openFOAM version.
Instructions seams to be there: http://openfoamwiki.net/index.php/Contrib_blockMeshDG
Yosmcer is offline   Reply With Quote
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
Define total mesh diclpacement in theta Direction omidiut CFX 1 November 10, 2013 04:28
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
