[snappyHexMesh] Solution Snappy Hex 2D Msh with Surface Layers and cyclic bc for symmetric geometry
Old   May 24, 2013, 08:38
Default Solution Snappy Hex 2D Msh with Surface Layers and cyclic bc for symmetric geometry
Felix
flexi182 is on a distinguished road
Dear Foamers,
1 week till now I tried to generate a 2D Mesh with snappyHexMesh. The mesh should have surface layers and cyclic boundaries.
Now I will present my workflow. This solution only works for symmetric geometries because I used mirrorMesh!
If you have questions, please ask
Here is the shell script:
#!/bin/sh
# clean folders
cd small_snappy
rm constant/polyMesh/*.gz constant/polyMesh/boundary
rm -r 0
rm log.*
# background mesh
blockMesh > log.blockMesh # Only the half of the geometry get an backroundmesh because we want mirror it later
# snappyHexMesh 3D
renumberMesh -overwrite
snappyHexMesh -overwrite  > log.snappy
setSet -batch middlePlane.setSet -noSync # Cut through the mesh, we want a patch with boundary layers for Extrusion
subsetMesh -overwrite halfBoxSlaveCells
flattenMesh
# extrudeMesh 2D extrude
cd ../small_extrude
rm -r 0
rm -r constant/polyMesh/
rm log.*
extrudeMesh > log.extrude
mirrorMesh > log.mirror
autoPatch 50 -overwrite
# Rename and convert patches
kate 0/polyMesh/boundary
createPatch -overwrite
checkMesh > log.mesh
cd ../
Have Fun!
flexi182 is offline   Reply With Quote
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 04:42
[snappyHexMesh] FOAM Warnings leading to no geometry, yet OpenFOAM says meshing finished w/o error edomalley1 OpenFOAM Meshing & Mesh Conversion 1 September 5, 2018 18:30
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges olek.warc OpenFOAM Meshing & Mesh Conversion 1 August 31, 2018 11:31
Problem with entire domain comprised of split hex cells Arzed23 Main CFD Forum 1 November 7, 2016 23:01
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
