-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   solve a single domain problem (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/120501-solve-single-domain-problem.html)
nandiganavishal July 8, 2013 11:36
Dear Foamers,
I have mapped and meshed a user defined structure (generated as .stl file) inside my cylindrical geometry using SnappyHexMesh. I would like to know, if OpenFOAM describes the mapped geometry only as a boundary (or patch). Is it possible to define this structure as part of the internal domain. The reason I am asking this is because I would like to solve the following equation in the entire domain (both mapped geometry and the cylindrical domain)
fvm::laplacian(eps_r(r),Phi(r)) == rho (r)
where, eps_r is 80 when r != r_map (r is the mesh point location and r_map is the mesh point of the mapped structure)
eps_r = 2 when r == r_map
rho(r) = user defined input value depending on r
Hence, I would like to know if we can define the entire system (mapped structure + cylindrical geometry) as a single domain so as to solve the problem in a single domain.
Please let me know
Thanks for the help.
Regards,
Vishal
