[Other] Command to make mesh in open Foam
Old   July 9, 2013, 01:29
Default Command to make mesh in open Foam
sonu
yash.aesi is on a distinguished road
I am new user of openFoam and i tried to solve one tutorial but i am having some problem regarding meshing and running it so can anybody tell me how to mesh and run a code in openFoam.
yash.aesi is offline   Reply With Quote
Old   July 9, 2013, 07:39
achyutan is on a distinguished road
First, you need to follow openfoam user guide to practice basic things like how to mesh, setting up a case etc. it is well explained there.
could you tell more about your problem so i can help ?
which tutorial case did u try ?
achyutan
achyutan is offline   Reply With Quote
Old   July 10, 2013, 02:46
Default helo
sonu
thanks achyutan , actually i am solving cavity problem and not able to mesh and run it but nw as u suggested to go through user guide i am able to run it .
thanks
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
