Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
SHM problem
Old   July 23, 2013, 07:08
Default SHM problem
Tom
samy902 is on a distinguished road
Hello everyone.
I am running a simulation with a two-building model. As you can see in the photo the mesh behind the frontal building is strange. I am quite a new OpenFOAM user and i can't seem to find the solution. You will find attached the SHMDict. Thank you in advance.
Note that i extracted the model from Google Sketch Up.
samy902 is offline   Reply With Quote
Old   July 24, 2013, 03:23
colinB is on a distinguished road
Dear samy902,
I can't see anything strange in your mesh.
Maybe it helps if you describe what you expect to see.
However please be aware that paraview has troubles to display
hexaedra cells so you have those strange lines across the cells.
there is a work around for that as far as I remember, but I don't recall
it in particular, so I advise you to use the forum search and have a look
for it (try keywords: hexaedra display paraview)
I hope I could help you a little bit
regards
colinB is offline   Reply With Quote
Old   July 24, 2013, 08:09
anonymous
aCFDuser is on a distinguished road
Hi samy902,
if you check the "Use VTKPolyhedron" option (left panel), you remove the extra lines that Paraview generates when you cut a mesh.
Another way to visualize your mesh is for example by:
1.- clicking on "select cell through" button (upper menu)
2.- going to filters --> extract selection
Regards
aCFDuser is offline   Reply With Quote
Old   July 24, 2013, 16:51
Tom
Thank you both for your valuable advices.
With regards
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
SHM add layers problem doubtsincfd OpenFOAM 0 June 6, 2011 12:01
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
