surfaceFeatureExtract surface.stl
Hi friends
I'm trying to make .emesh file from my .stl file for snappyHesh. but when I apply the command: srfaceFeatureExtract,this happens: FOAM FATAL ERROR: Cannnot read "surface.stl" From function triSurface::read(const fileName&, const word&, const bool) in file triSurface/triSurface.C at line 369. can you give a comment about it? Many thanks |
Dear Reza
you might saved your STL file in binary format :), so i guess if you save it in ASCII format, then error would be solved |
many thanks
would you help me how to change .stl to binary one?
I tried autocad, but it didnt work |
Open your STL file in paraview and save in in STL format ASCII one ;)
same error
Hi Sam,
Thank you for your help, I saved the file in Ascii format and run it again, but the same error appeared: Rezas-MacBook-Pro:chalk reza$ surfaceFeatureExtract -includedAngle 150 pores.stl features /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : surfaceFeatureExtract -includedAngle 150 pores.stl features Date : Aug 26 2013 Time : 09:57:48 Host : "Rezas-MacBook-Pro.local" PID : 483 Case : /Volumes/OpenFOAM-v2.1.1/OpenFOAM-2.1.1/tutorials/mesh/snappyHexMesh/chalk nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Feature line extraction is only valid on closed manifold surfaces. Surface : "pores.stl" Output feature set : "features" --> FOAM FATAL ERROR: Cannnot read "pores.stl" From function triSurface::read(const fileName&, const word&, const bool) in file triSurface/triSurface.C at line 369. FOAM exiting What do you think???? thanks |
i have no idea, you may want to post your test case here, then OpenFOAM users can help you
same thing
1 Attachment(s)
Hi friends,
As I told my problem, I could not use surfacefeature extract and above message come to my terminal after run. I tried with many cases and I got the same result!!! I uploaded one of the stl files. If you can see that what's the problem, it would be a great help for me. Thank you in advance |
1 Attachment(s)
did you edit your surfaceFeatureExtractDict at all?
However, it works for me ;) , i used OF-2.2.0, and i add working test case with your stl file to use following test case: 1- open zip file 2- run script Code:
./preAllrun |
Thanks
Many thanks for your help. As you helped me I could solve the problem. In my case, OF could not find the directory but it showed an error about not being able to read the file. I change the path and it work.
Now I generate the mesh, but since the surface structure is complicated, I do not know how to define the boundary (Wall type) on the surface. Is there any feature which help me to define the boundary on the surface? Regards |
surfaceFeatureExtract not working in OpenFOAM-v3.0+
Hi all,
I am trying to use the surfaceFeatureExtract in the motorBike (OpenFOAM-v3.0+) tutorial case; however it is not working. It always says "command not found". Do you know if the surfaceFeatureExtract still in use in OpenFOAM-v3.0+ ? How to solve this problem ? Thanks. |
surfaceFeatureExtract with OpenFOAM-v3.0+
Hi Rophys,
I can assure you that surfaceFeatureExtract still works in OpenFOAM-v3.0+. But I don't know what is wrong with it in your case. Can you post more details ? Are you sure of your installation ? Mary |
Hi Mary,
Thanks for that. I already solved the problem =) Cheers, Rodrigo |
I have also the same problem with command surfaceFeatureExtract, and got message command not found, on OpenFOAM-v3.0+. What to do? Thanks |
Hi all,
I also have the problem with "command not find". My installation looks correct, solvers work fine apart of that. Rophys, how did you solve the problem? Best regards Julien |
I am having this same issue with 3.0+. Considering rolling back to a previous version, but if it is assured to work then I am not sure how to fix the problem.
I have also the same problem with command surfaceFeatureExtract, and got message command not found, on OpenFOAM4.0.
Please tell me how to solve it. Thanks ZX |
I solved the issue by removing the installation and installed it again. Now works.
Thanks, I did it too. Now it works
