[snappyHexMesh] Sharp edges not being refined properly
Old   September 10, 2013, 14:16
Default Sharp edges not being refined properly
Eli Baldwin
ebaldwin is on a distinguished road
I'm new to snappyHexMesh and I've read through the snappy user guide as well as all relevant cfd-online posts. I am trying to make a mesh for a two nozzle impinging spray. The mesh will include one of the nozzles and a symmetric boundary on the plane where the jets collide. There is a second symmetric plane through the nozzle to minimize cell count. For now I am working with a single refinement cylinder of level 4 around the nozzle.
I am using explicit edge / feature snapping with surfaceFeatureExtract. The two primary problems that I am observing are,
1. Rounding of some sharp edges
2. Disruption of the symmetric plane
Attached are some screenshots of the current mesh snappyHexMesh is generating. There is a refinement cylinder with a refinement level of 4 around the nozzle. The snappyHexMeshDict is also attached. Any help is welcome!
Thanks,
Eli
ebaldwin is offline   Reply With Quote
Old   September 11, 2013, 05:28
Artur's Avatar
Artur
Artur will become famous soon enough
I must say that edge problem looks like nothing I've seen before. Have you tried previewing the extracted feature lines and checking that they are correct?
(use
surfaceFeatureConvert constant/triSurface/ImpingingJet0.eMesh ImpingingJet0.obj
and open the .obj file in paraview).
Artur is offline   Reply With Quote
Old   September 11, 2013, 09:59
Eli Baldwin
Yes, the extracted lines look to be right on.
Old   September 11, 2013, 10:07
Artur's Avatar
Artur
Hmmm.. Any chance of you uploading your geometry then?
snappyhexmesh, surfacefeatureextract
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[cfMesh] layer addiction on sharp edges student666 OpenFOAM Community Contributions 1 October 27, 2020 18:22
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
