[snappyHexMesh] snappyHexMesh - problem using *.obj file
Old   October 3, 2013, 06:09
Default snappyHexMesh - problem using *.obj file
Vishal
inf.vish is on a distinguished road
I am using a *.obj file as my geometry file instead of a *.stl file.
The problem is that stl files do not show curves whereas the curves on the geometry can be seen in *.obj file. Thus i am trying to use an obj file. The obj file i am trying to use has been generated using ProE wildfire 4. The geometry was exported in wavefront *.obj format.
The problem is that i cannot run surfaceFeatureExtract cause openFoam gives the following error -
Create time
Reading surfaceFeatureExtractDict
Surface : "pipe.obj"
Feature line extraction is only valid on closed manifold surfaces.
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 0 the label 0
file: IStringStream.sourceFile at line 0.
From function operator>>(Istream&, word&)
in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Also if i do not run surfaceFeatureExtract and simply run snappyHexMesh -overwrite, i get the following errors -
Create time
Create mesh for time = 0
Read mesh in = 2.52 s
Overall mesh bounding box : (-51 -51 -1) (51 51 51)
Relative tolerance : 1e-06
Absolute matching distance : 0.00015333623
FOAM exiting
Can anyone explain what i am doing wrong? The obj file seems to work flawlessly with the motorbike tutorial.
I am attaching my SHMDict and obj files in this zip file - pipe.zip
inf.vish is offline   Reply With Quote
Old   October 4, 2013, 01:06
Default [solved]
Vishal
I solved the problem.
Just delet everything else in the *.obj file apart from
v
vn
vt
f
Old   October 6, 2013, 17:00
Miro
miro2000 is on a distinguished road
Is there a way to convert it to .stl? I bet there is. Maybe surface convert can do that?
miro2000 is offline   Reply With Quote
Old   October 6, 2013, 23:20
Vishal
Hey,
Yeah there is a way to convert it to .stl. It cannot be done directly though using surfaceConvert. You have to open the .obj file in paraview and then File> Save Data - save as .vtk . Go to the directory where the file is saved and perform surfaceConvert <vtk_file_name> <stl_file_name>.
Old   October 7, 2013, 03:54
Miro
Nice. Anyway, maybe you can do that with foamToVTK?
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
