Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Is the changing on size of baground mesh of blockMesh; effect on the SHM result?
Old   October 12, 2013, 09:57
Default Is the changing on size of baground mesh of blockMesh; effect on the SHM result?
s.m
saeideh mohamadi
s.m is on a distinguished road
i am simulating the flow over an airfoil, i use snappyHexMesh for meshing the domain around airfoil.
As we know in the first step is to produce a rectangular domain with blockMesh as background mesh of SHM
1. For the first snappyHexMesh run, i creat this backgraound mesh
convertToMeters 1;
vertices
(-1.2 -2.2 0.05)
( 5 -2.2 0.05)
( 5 2.2 0.05)
(-1.2 2.2 0.05)
(-1.2 -2.2 0.15)
( 5 -2.2 0.15)
( 5 2.2 0.15)
(-1.2 2.2 0.15)
blocks
hex (0 1 2 3 4 5 6 7) (182 176 1) simpleGrading (1 1 1) //(30*6.2 40*4.4 1)
2. For the second run of SHM, i change the size of the domain from 5 to 10 in +x axis and also the number of the subdivisions in this direction from 182 to 336:
convertToMeters 1;
vertices
(-1.2 -2.2 0.05)
( 10 -2.2 0.05)
( 10 2.2 0.05)
(-1.2 2.2 0.05)
(-1.2 -2.2 0.15)
( 10 -2.2 0.15)
( 10 2.2 0.15)
(-1.2 2.2 0.15)
blocks
hex (0 1 2 3 4 5 6 7) (336 176 1) simpleGrading (1 1 1) //(30*11.2 40*4.4 1)
As you see, i change the size of the domain over th +x axis and the instructions on this direction with eachother :
"(-1.2 to 5) --> (-1.2 to 10) & (30*6.2=182) --->( 30*11.2=336)
Now my question is:
Are thease two mesh the same as eachother?
all of the setting are the same for thease two mesh, only the size of domain for the first mesh over +x axis is till 5 and for the other one is till 10 in +x direction.
as you see the size of the cells that are filled the bacground domain mesh, are (1/30 * 1/40) for two mesh.
and all the settings for snappyHexMeshDict are also the same.
please clarify this question for me, if you can
Thank you very much.
s.m is offline   Reply With Quote
Thread Tools
Trackbacks are On
Layers:problem with curvature giulio.topazio OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 22, 2012 09:03
Effect of adding layers with sHM Nucleophobe OpenFOAM Native Meshers: snappyHexMesh and Others 4 August 20, 2012 16:45
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
