Setting up a periodic heat transfer case with cooling rips
5 Attachment(s)
Hey Guys,
I'm setting up my first testcase. Like the title says it is a periodic heat transfer case. Periodic means in my case its an infinite loop of the same geometry bodies. blockMesh is already running but i don't know if i have the right snappyHexMesh setup. I have added some pictures to illustrate my case. I worked my way through the "motorBike" sHMDict and changed the necessary values. So here is my .stl sHMDict and blockMeshDict file so you can try it by yourself. If you also need anything else let me know! Attachment 26344 Attachment 26343 Attachment 26345 just rename it to kanal.stl otherwise no upload possible Attachment 26309Attachment 26310 |
1 Attachment(s)
Ok so now I'm 1 step further. sHM is running through (10 minutes :D), think my refinement levels are too small.
I've created *.eMesh with surfaceFeatureExtract. Nevertheless i have still some snapping problems at the edges, see attached picture. Has someone suggestion what i could change? By the way surfaceCheck says my *.stl is not closed, does this matter for my case or do i have to close it and if yes how? Attachment 26334 --- I have to apologize for my bad english, i'm a bit out of practice. Greetings |
