[Gmsh] gmsh STL
Old   January 13, 2013, 11:43
Default gmsh STL
David Doose
huitetquatre is on a distinguished road
I want to generate a mesh around an object using gmsh. This object is defined using a STL file.
My current geo file is organised as follow:
1/ importing the STL object;
2/ creating the bounding box around the object;
3/ physical surface definition.
I've got different problems:
- I don"t know how to link the surface of the object with the different surfaces of the box. Consequently, the generated mesh with gmsh is not taking into account the STL object.
- How can determine the physical entities (surface and volume) ?
The geo file is the following one:
// STL Object
// merge a surface mesh
Merge "cone.stl";
// add a geometrical volume
Surface Loop(1) = {1};
Volume(1) = {1};
// Bounding Box
l = 1;
xmin = -10;
xmax = 10;
ymin = -10;
ymax = 10;
zmin = -10;
zmax = 10;
Point(1000) = {xmin, ymin, zmin, l};
Point(1001) = {xmin, ymin, zmax, l};
Point(1010) = {xmin, ymax, zmin, l};
Point(1011) = {xmin, ymax, zmax, l};
Line(2001) = {1000, 1001};
Line(2002) = {1001, 1011};
Line(2003) = {1011, 1010};
Line(2004) = {1010, 1000};
Line Loop (2005) = {2001, 2002, 2003, 2004};
Plane Surface(10006) = {2005};
box[] = Extrude {(xmax-xmin), 0, 0}{
Surface{10006};
// Layers{1};
Delete { Volume{box[1]}; }
// TODO
// Volume(4000) = {?};
// Physics
// Physical Surface("back") = {?};
// Physical Surface("front") = {?};
// Physical Surface("top") = {?};
// Physical Surface("bottom") = {?};
// Physical Surface("left") = {?};
// Physical Surface("right") = {?};
// Physical Surface("object") = {?};
// Physical Volume("internal") = {?};
huitetquatre is offline   Reply With Quote
Old   January 16, 2013, 08:46
David Doose
Problem solved.
Old   December 5, 2013, 01:07
Albert Pinto
Abracurcix is on a distinguished road
Hello David,
Could you please share with us as to how you solved this problem?
Thanks,
Albert
Abracurcix is offline   Reply With Quote
Old   December 13, 2013, 00:56
Albert Pinto
Anyone else has any suggestions regarding generating meshes around STL objects with GMSH? Any examples would be helpful. Please?
Albert
Originally Posted by Abracurcix View Post
Hello David,
Thanks,
Albert
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[Gmsh] Gmsh STL import error me3840 OpenFOAM Meshing & Mesh Conversion 9 October 9, 2016 20:52
[Gmsh] boundary conditions with Gmsh stl Bercht OpenFOAM Meshing & Mesh Conversion 1 July 10, 2012 11:04
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
STL to gmsh nomad OpenFOAM 2 August 10, 2009 04:09
