[snappyHexMesh] orthogonal cells marked as nonOrthogonal
Old   November 21, 2013, 08:30
Default orthogonal cells marked as nonOrthogonal
colinB is on a distinguished road
Hi Foamers,
I have some troubles with cells which are marked as nonOrthogonal
but are according to my interpretation perfectly orthogonal.
checkMesh says maxOrth: 75.xxx with 10k cells in a mesh of 3.1M cells.
I'm using LTSInterfoam in a more or less simple channel flow with a ship.
The cells causing troubles are created with a refinementBox in sHM
If somebody could give me an explanation to that phenomena and maybe
an explanation on how I can avoid them, would be great.
See attached some pictures which should illustrate the problem:
If you have further questions or need more information let me know
regards
Colin
colinB is offline   Reply With Quote
Old   November 21, 2013, 08:31
some more pics:
thx for your trouble
Old   January 22, 2014, 09:24
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Only the cells that lie between different levels of refinement are affected, right? This is caused by the hanging nodes introduced by the mesher in order to achieve the refinement.
Check this post http://www.cfd-online.com/Forums/ope...tml#post452712
The cells fall into checkMesh's definition of a non-orthogonal cell although the cell - to the user - seems perfectly orthogonal.
GerhardHolzinger is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh Problem 96faizizzuddin OpenFOAM Meshing & Mesh Conversion 10 October 10, 2022 06:45
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 01:16
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 19:18
Position of cells in a orthogonal grid alberto OpenFOAM Running, Solving & CFD 2 February 6, 2008 12:28
