Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Extract feature edges in paraview
Old   December 15, 2013, 06:42
Default Extract feature edges in paraview
Klaus
strakakl is on a distinguished road
HI all,
on the snappyWiki (https://sites.google.com/site/snappywiki/snappyhexmesh/snappyhexmeshdict#TOC-Explicit-feature-edge-refinement) i found that it is possible to extract feature edges in paraview.
"Users can generate feature edge meshes in Paraview by using the Feature Edges filter. Data can be saved in VTK (ASCII) format and then be used by snappyHexMesh."
I tried this with my geometry and saved the edges to a file "edges.vtk", this is a quite straight forward procedure. But how do i use this vtk file in snappyHexMesh? I tried
features
            file "edges.vtk";
            level 3;
but this gives me an error
--> FOAM FATAL IO ERROR:
problem while reading header for object edges.vtk
file: /home/ak113859/OpenFOAM/ak113859-2.2.0/run/snappy/splitableBarrel/meteringzone/constant/triSurface/edges.vtk at line 1.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 95.
FOAM exiting
Does anyone has an idea how to use the vtk file?
Cheers,
Klaus
strakakl is offline   Reply With Quote
Old   December 16, 2013, 03:34
Default seems to be bug in OF-2.2.0
Klaus
Hi there,
to answer my own post, seems to be a bug in 2.2.0, http://www.openfoam.org/mantisbt/view.php?id=796
best,
Klaus
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
SurfaceFeatureExtract Foam::error::printStack donQi OpenFOAM Meshing & Mesh Conversion 1 August 15, 2013 00:43
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
