-   OpenFOAM Native Meshers: snappyHexMesh and Others (
-   -   trouble with snappyhex (
arapuraz January 3, 2014 15:24
I am currently trying to run the motorbike tutorial in OpenFoam. The tutorial was previously set up for a 8 core computer, I only have a quad core computer. I tried to play around with the decomposePardict and finally found one that works. I am now however struggling to get the snappyhex running in parallel. I used the following code
snappyHexMesh 4 -overwrite
but I get the follwoing error when running
Usage: snappyHexMesh [OPTIONS]
-case <dir> specify alternate case directory, default is the cwd
-checkGeometry check all surface geometry for quality
do not execute functionObjects
-overwrite overwrite existing mesh/results files
-parallel run in parallel
-roots <(dir1 .. dirN)>
slave root directories for distributed running
-writeLevel write pointLevel and cellLevel postprocessing files
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.2.2 (see
Build: 2.2.2
Wrong number of arguments, expected 0 found 1
FOAM exiting
I was wondering if anyone knew why I am getting this problem and how to overcome it.
lovecraft22 January 3, 2014 18:02
Try with
runParallel snappyHexMesh 4 -overwrite
arapuraz January 4, 2014 07:20
hi there I tried the command and it unfortunately did not work, it said the following error
bash: runParallel: command not found...
I think the main problem is with the snappyHexMeshDict, I might be wrong.
lovecraft22 January 4, 2014 09:52
Try this then:
mpirun -np 8 snappyHexMesh -overwrite -parallel
Of course you need to run decomposePar first.
arapuraz January 4, 2014 10:05
Thank you for your help, was stuck on this for weeks.
arapuraz January 4, 2014 11:23
I was following the script file that came with the motorbike tutorial. Once again i am stuck so here is the full script
cd ${0%/*} || exit 1 # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# copy motorbike surface from resources folder
cp $FOAM_TUTORIALS/resources/geometry/motorBike.obj.gz constant/triSurface/
runApplication surfaceFeatureExtract
runApplication blockMesh
runApplication decomposePar
runParallel snappyHexMesh 6 -overwrite
#- For non-parallel running
#cp -r 0 > /dev/null 2>&1
#- For parallel running
ls -d processor* | xargs -i rm -rf ./{}/0 $1
ls -d processor* | xargs -i cp -r ./{}/0 $1
runParallel patchSummary 6
runParallel potentialFoam 6 -noFunctionObjects -writep
runParallel $(getApplication) 6
runApplication reconstructParMesh -constant
runApplication reconstructPar -latestTime
# ----------------------------------------------------------------- end-of-file
I am stuck again on the
I tried to change the code the following code
mpirun -np 4 $(getApplication) 4 -parallel
the mpirunb ti and the rest of the line worked fine befor the only part causing problems is the
$(getApplication) 4
thank you
lovecraft22 January 6, 2014 17:05
That is a variable you have to set somewhere, which indicates the solver you want to use.
If you want to use simpleFoam, just type
mpirun -np 4 simpleFoam -parallel
instead and you should be able to walk around it.
arapuraz January 6, 2014 17:18
Ofcourse :o .... Thank you once again
Tobi January 8, 2014 03:17
just one hint.
You said that you used the scripts but I think you typ in the commands by yourself, arenīt you?
If you do this you have to be sure the aliases are loaded in your terminal:
in that file you find the alias
If you did not load that file you can not use that keywords.
I think that is your Problem. Hence you just able to work with the official Linux commands:
mpirun -np 20 snappyHexMesh -parallel  // example
