January 4, 2014, 11:57 |
Smoothing the surface
Tobias Holzmann
Rep Power: 51 |
Dear all,
I am working with sHM a long time but I never solved the following problem! If I am using multi-region cases I got bad surface approximation on curved surfaces (see the attached pictures). If I mesh just one region - everything is fine. Does someone know any solutions for this? I think this depend on the multi-domain function of sHM. Maybe it happend after splitting the mesh?! Regards Tobi |
January 4, 2014, 18:24 |
But can you exactly post what is the problem? Wasn't able to figure out it from the pictures you've attached.
January 5, 2014, 12:32 |
#3 | |
Tobias Holzmann
Rep Power: 51 |
Hi, the problem - maybe its not a problem - is that the surface is not smooth enough. If I just mesh the cup region then I get a extreme accurate surface approximation. If I am home again I will do this again and post a new picture so that the differences are clear. To clear it up: - one region: accurate and smooth surface - multi region: no smooth surface (see pictures) - snatchy surface. Regards Tobi |
January 5, 2014, 17:10 |
Tobias Holzmann
Rep Power: 51 |
Okay.
In the attachment you find the surfaces after meshing but just the cup (no multidomain with cellZones and faceZones). The question now. Is it possible to get such a surface with the multidomain meshing too or not? Regards Tobi |
January 9, 2014, 03:53 |
Michael
Rep Power: 13 |
I do not know where these issues come from, but I was able to fix it by trying different mesh settings.
You have to play with the values: nSolveIter, nRelaxIter, nFeatureSnapIter. explicitFeatureSnap true and multiRegionFeatureSnap false did a better job for me than implicitFeatureSnap. Furthermore the meshQualityControls may have an influence on the result. As a starting point you may use my settings: Code:
snapControls { nSmoothPatch 3; tolerance 1.0; nSolveIter 60; nRelaxIter 5; nFeatureSnapIter 5; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } Code:
meshQualityControls { maxNonOrtho 100; maxBoundarySkewness 40; maxInternalSkewness 8; maxConcave 80; minVol 0; minTetQuality 1e-30; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } |
January 9, 2014, 08:50 |
Tobias Holzmann
Rep Power: 51 |
I will check it out. I used explizit Feature snapping and have more iterations on smoothing as you mentioned but I will check you Settings. It only appears with multi-Region! |
June 4, 2018, 10:18 |
Hello Tobi,
Have you figured out something to smooth surface while using SHM for multiregion meshing? I have seen your tutorials on your website for mutiregion meshing. In those tutorials, surface is not smooth. Did you face any problem in simulation due to non-smooth surface? Thank you Regards |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
smoothing surface | farzad66 | CFX | 1 | May 24, 2012 18:39 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
