[snappyHexMesh] Help with snappyHexMeshDict parameters |
March 4, 2014, 16:52 |
LA
I have a little CFD experience and I'm trying to use openFOAM to determine the drag coefficient for a few shapes. I know that eventually I must use a turbulence model, but for now I've managed to run a preliminary transient simulation using icoFOam. However, the Courant number blows up unless I use dt=0.0001 or close to that. I suspect that my mesh may be the problem since I go this warning from checkMesh: ***Max skewness = 4.68373, 1 highly skew faces detected which may impair the quality of the results Could someone please take a look at my setup and recommend better parameter values for the snappyHexMeshDict? I'm attaching the required files in SnappyFiles.zip and a sketch of the physical domain in Domain.zip Thanks so much, Lowis5 |
Parameters of a good airfoil mesh | CharlieBra7o | Mesh Generation & Pre-Processing | 4 | November 20, 2018 14:42 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
Parameters rhoSimpleFoam | marcus85 | OpenFOAM Pre-Processing | 0 | May 15, 2013 09:36 |
Turbulence model parameters and equations | Maximus91 | Main CFD Forum | 1 | October 24, 2012 13:20 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 02:05 |
