Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
does SnappyHexMesh allows intersection of refinement regions
Old   March 21, 2014, 17:41
Default does SnappyHexMesh allows intersection of refinement regions
Zeliang Xu
douglasx is on a distinguished road
Hi Foamers,
I am currently using snappyHexMesh based on DTCHull tutorial in the 2.3 version.
In the tutorial, refinement in Z direction near the free surface is done by having small spacing in Z direction in blockMeshDict. Then some topoSet and refineMesh in X and Y directions are used to make sure block meshes near the ship hull is not having too big aspect ratio.
I am trying to add more refinement to this case by adding a cone shape refinement box (imported into SnappyHexMesh as stl file) behind the hull to capture Kelvin wake. However, in snappyHexMesh, it reports "cell *** of level * uses more than 8 points of equal or lower level".
After some tests I figured out that the problem is that the cone shape refinement box is intersecting with the refineMesh boxes. And when I split the cone into different parts, with each part fitted into each refineMesh box rather than making intersections, there is no more problem. However, splitting the cone left gaps in between.
I am wondering if this is the normal solution or there are more ways of going around the problem? So the regions refined by refineMesh cannot have any intersections with other refienment boxes?
I have attached a figure showing the basic configuration of my cone shape refinement box, ship hull and refineMesh boxes.
Any comment is appreciated.
Thanks,
Zeliang
douglasx is offline   Reply With Quote
Old   April 2, 2014, 04:00
thg
Thorsten Grahs
thg is on a distinguished road
Hi Zeliang,
in principle there should be no problem with intersecting refinment regions or volumes.
But from the error message I would derive that you try to refine a mesh region (cells)
which was already deformed/snappped. Snappy can oly refine on pure hexyeder elemnts.
For me it look that you try to refine a mesh which is already processed with snappyHex. You should start from the blockMesh.
thg is offline   Reply With Quote
Old   April 2, 2014, 09:30
Zeliang Xu
Hi Thorsten,
Thank you for your reply. The procedure I took to building the mesh is blockMesh, refineMesh, snappyHexMesh, and the error message takes place. When I split my refinement regions to avoid intersections, the error message goes away.
I have also tried the suggestions of "blockMesh, snappyHexMesh, refineMesh" procedure. For this procedure, I do not have to worry about intersection of regions that upsets snappyHexMesh, but the resulting mesh quality is not as good (thousands of highly skewed cells).
So there is some kind of trade-offs.
Have you tried refineMesh+snappyHexMesh combination and have the ideal mesh?
Thanks,
Zeliang
Thread Tools
Trackbacks are On
Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Native Meshers: snappyHexMesh and Others 1 April 22, 2013 02:32
snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 03:59
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 04:23
