Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Explicit feature edge ref&snap in OF2.2
Old   May 9, 2014, 11:39
Default Explicit feature edge ref&snap in OF2.2
Elo´se
Eloise is on a distinguished road
Hello Foamers,
I struggle with the new feature edge handling in OF2.2.x. I hope someone can help me there!
What I want to do here is to refine the feature edges through the "old" explicit method: I give an eMesh file in the "features" section with a given refinement level. Then, I want the mesh to snap on the same feature edges. Here are some parts of what I have in snappyHexMeshDict to attempt achieving it:
castellatedMeshControls
    features
    ( { file "Column_F.eMesh"; level 4; } );
    refinementSurfaces
    { Column
        { level (3 4); }
    resolveFeatureAngle 30;
snapControls
    nSmoothPatch 3;
    tolerance 1.0;
    nSolveIter 300;
    nRelaxIter 5;
    // Feature snapping
        nFeatureSnapIter 10;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
As you can see from the attached image (the feature edges from the eMesh are highlighted in white):
1) The mesh is only partially refined at level 4 along the feature edges.
2) The mesh didn't snap along the feature edges.
As I have several eMesh to insert with different refinement levels, I don't want to use the implicit feature edge handling. Can anyone give me some advices?
Regards,
Elo´se
Eloise is offline   Reply With Quote
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Understanding feature edge refinement and snapping Horus OpenFOAM Native Meshers: snappyHexMesh and Others 1 May 31, 2012 12:08
How to use Explicit feature edge refinement ziemowitzima OpenFOAM Native Meshers: snappyHexMesh and Others 3 April 22, 2010 09:16
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
