July 15, 2014, 08:33 |
defining two cellZone in SHM
Hi all,
I'm trying to define two cellzone in SHMdict: one is rotating, the other is porous zone. here the SHM dict. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { inlet.stl {type triSurfaceMesh; name inlet;} outlet.stl {type triSurfaceMesh; name outlet;} wallComp.stl {type triSurfaceMesh; name wallComp;} wallAsp.stl {type triSurfaceMesh; name wallAsp;} boccaglio.stl {type triSurfaceMesh; name boccaglio;} blade.stl {type triSurfaceMesh; name blade;} wallMan.stl {type triSurfaceMesh; name wallMan;} wallExt.stl {type triSurfaceMesh; name wallExt;} tubi.stl {type triSurfaceMesh; name tubi;} dominio.stl {type triSurfaceMesh; name volume;} porous {type searchableBox; min (-0.235 -0.3922 -0.087); max ( -0.165 -0.2072 0.0875);name porous} rotating {type searchableCylinder; point1 (0. -0.0072 0.); point2 ( 0. -0.0279 0.); radius 0.078; name rotating;} }; castellatedMeshControls { maxLocalCells 1500000; //max cells per CPU core maxGlobalCells 3000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.10; nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "inlet.eMesh"; level 0;} {file "outlet.eMesh"; level 0;} {file "wallComp.eMesh"; level 3;} {file "wallAsp.eMesh"; level 2;} {file "boccaglio.eMesh"; level 5;} {file "wallMan.eMesh"; level 2;} {file "blade.eMesh"; level 5;} {file "tubi.eMesh"; level 5;} {file "wallExt.eMesh"; level 0;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { inlet {level (0 0);} outlet {level (0 0);} wallComp {level (3 3);} wallAsp {level (3 3);} boccaglio {level (5 5);} wallMan {level (3 3);} blade {level (5 5);} tubi {level (5 5);} wallExt {level (0 0);} rotating {level (5 5); regions{}; faceZone MRF; cellZone MRF; zoneInside true;} porous {level (5 5); regions{}; faceZone porous; cellZone pourous; zoneInside true;} } resolveFeatureAngle 60; //was80 Resolve sharp angles // Default 30 refinementRegions // In descending levels of fine-ness {volume {mode distance; levels ((0.0008 3) (0.002 2) (0.01 1));}}//((0.0008 4) (0.002 3) (0.01 2));}} // was ((0.001 4) (0.003 3) (0.01 2)) locationInMesh (0. -0.05 0.); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } ECC ... I have a look deeper into forum, but I didn't find anything similar to my question. Can someone help me please? Regards Michele |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 02:03 |
[snappyHexMesh] SHM not defining faces | bullmut | OpenFOAM Meshing & Mesh Conversion | 0 | January 8, 2016 04:55 |
[snappyHexMesh] defining boundary condition in SHM | mihaipruna | OpenFOAM Meshing & Mesh Conversion | 3 | April 25, 2012 13:33 |
