[snappyHexMesh] How to use featureEdge refinement
Like Tree1Likes
  • 1 Post By Tobi
Old   November 27, 2014, 10:50
Default How to use featureEdge refinement
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I read some threads about featureEdge refinement and some problems which occure if you apply featureEdge refinement. Therefor I checked out a few things and got some nice and interesting knowledge that I want to share with you.
I just wanted to mesh a cylinder and refine the features with level 2. The result is in picture #1. You see on the left side, that the feature refinement is not applied in the whole region. Only a few cells are refined with level 2. After playing around with blender and the eMesh I found, that sHM has some bug or more like a problem, finding these lines after refinement level 1 because if I move the feature edge on the left down the z-axis with 0,00001 m you can see that the result is like you expect (see picture 2).
I also tried to use the levels instead of level to check if its working with distances and what we see is what we expect. The result is like in picture 2. Done (:
Summary
  • In some cases it happens, that sHM does not realize the featureEdge for refinement. Maybe there is some tolerance parameter that can be set or should be introduced to fetch these lines in the new snappyHexMesh version.
  • To solve that problem you have to move your featureEdge a bit, like I did with blender or,
  • Just use levels (( )) and some distance to get these lines fetched.
  • The error also could not be solved after scaling the featureEdge and background mesh with factor 1000. Its getting better but still you will not have the expected result.
Hope it will help some guys,
Take care
Romarius likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 13:30
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
