December 3, 2014, 10:52 |
How to create an MRF zone ?
amine
Rep Power: 12 |
I have convert a fluent mesh to openfoam format (see picture). How I can create a rotor zone in openfoam ? Thanks |
December 4, 2014, 09:49 |
#2 | |
Dongyue Li
Rep Power: 17 |
1. by block. U should name the rotational block and stationary block. then openfoam will tell these two different zones. 2. by tet mesh U should draw a interface like a cylinder, then name it as rotational body, the others as stationary body, then compute tet mesh, you will have two zones. Best, |
December 8, 2014, 10:45 |
amine
Rep Power: 12 |
I have done this step under ANSYS MESHING (i have two rotor zone and one stator zone). but when i execute this instruction fluentMeshToFoam stirredtank.msh The boundary (interface) of two rotor zone is merged into one new patch "default_wall" Thanks Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : fluentMeshToFoam stirredtank.msh Date : Dec 08 2014 Time : 16:36:32 Host : "amine-VirtualBox" PID : 17197 Case : /home/amine/OpenFOAM/amine-2.3.0/run/aminetuto/exo3cuve nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown: ( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Dimension of grid: 3 Number of points: 133864 number of faces: 931682 Number of cells: 415231 Reading points Reading points Reading mixed faces Reading mixed faces Reading mixed faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Reading uniform faces Other readCellGroupData: 4 1 b44c 1 0 Reading mixed cells Other readCellGroupData: 5 b44d 183c9 1 0 Reading mixed cells Other readCellGroupData: 6 183ca 655ff 1 0 Reading mixed cells Read zone1:1 name:interior-ph patchTypeID:interior Reading zone data Read zone1:2 name:interior-bh patchTypeID:interior Reading zone data Read zone1:3 name:interior-sphere_cuve patchTypeID:interior Reading zone data Read zone1:4 name:ph patchTypeID:fluid Reading zone data Read zone1:5 name:bh patchTypeID:fluid Reading zone data Read zone1:6 name:sphere_cuve patchTypeID:fluid Reading zone data Read zone1:9 name:tank patchTypeID:wall Reading zone data Read zone1:10 name:shaft patchTypeID:wall Reading zone data Read zone1:11 name:wall_ph patchTypeID:wall Reading zone data Read zone1:12 name:wall_bh patchTypeID:wall Reading zone data Read zone1:13 name:contact_region-src patchTypeID:interface Reading zone data Read zone1:14 name:contact_region-trg patchTypeID:interface Reading zone data Read zone1:15 name:contact_region_2-src patchTypeID:interface Reading zone data Read zone1:16 name:contact_region_2-trg patchTypeID:interface Reading zone data Found unknown block:(37 Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Found end of section in unknown: ) Found end of section in unknown:) Found end of section in unknown: ) Found end of section in unknown:) FINISHED LEXING dimension of grid: 3 Creating shapes for 3-D cells Building patch-less mesh...--> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627 Found 33740 undefined faces in mesh; adding to default patch. done. Building boundary and internal patches. Creating patch 0 for zone: 1 start: 1 end: 101984 type: interior name: interior-ph Creating patch 1 for zone: 2 start: 101985 end: 218394 type: interior name: interior-bh Creating patch 2 for zone: 3 start: 218395 end: 897942 type: interior name: interior-sphere_cuve Creating patch 3 for zone: 9 start: 897943 end: 912448 type: wall name: tank Creating patch 4 for zone: 10 start: 912449 end: 915708 type: wall name: shaft Creating patch 5 for zone: 11 start: 915709 end: 917426 type: wall name: wall_ph Creating patch 6 for zone: 12 start: 917427 end: 919386 type: wall name: wall_bh Creating patch 7 for zone: 13 start: 919387 end: 922504 type: interface name: contact_region-src Creating patch 8 for zone: 14 start: 922505 end: 925634 type: interface name: contact_region-trg Creating patch 9 for zone: 15 start: 925635 end: 928762 type: interface name: contact_region_2-src Creating patch 10 for zone: 16 start: 928763 end: 931682 type: interface name: contact_region_2-trg Patch interior-ph is internal to the mesh and is not being added to the boundary. Patch interior-bh is internal to the mesh and is not being added to the boundary. Patch interior-sphere_cuve is internal to the mesh and is not being added to the boundary. Adding new patch tank of type wall as patch 0 Adding new patch shaft of type wall as patch 1 Adding new patch wall_ph of type wall as patch 2 Adding new patch wall_bh of type wall as patch 3 Patch contact_region-src is internal to the mesh and is not being added to the boundary. Patch contact_region-trg is internal to the mesh and is not being added to the boundary. Patch contact_region_2-src is internal to the mesh and is not being added to the boundary. Patch contact_region_2-trg is internal to the mesh and is not being added to the boundary. --> FOAM Warning : fluent mesh has 12296 undefined boundary faces. Adding undefined faces to new patch `default_wall` Writing mesh... to "constant/polyMesh" done. End |
Create Patch for MRF Wind Turbine Simulation | Bernoulli666 | OpenFOAM Pre-Processing | 1 | August 27, 2017 02:21 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 19:39 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
