March 3, 2015, 12:12 |
Boundary Layer collapse
Rep Power: 11 |
Hi all!
Basically, I would like to mesh a 3D elliptic NACA profile and to create a nice boundary layer mesh. Unfortunately, the BL collapse at some unexpected point, and is not contine (see image attached). Do anyone has any clue or advices that can help me to sort it out??? Thank you for your help Jojosaxo |
March 5, 2015, 15:10 |
anonymous
Rep Power: 12 |
Try to increase the background mesh refinement , and use featureEdges to improve the snapping and layer adding process
March 19, 2015, 09:58 |
Hi all,
sorry to use this thread for my problem, but in some way I think it is quite related. My personal issue is about layer collapsing between patches: I have an inlet and a wall; inlet patch does not have layers. Enclosed picture explains better what I mean: at inlet side layers are collapsing in a strange way, and in every patch where I don't want have layers too. Can someone suggest me what parameter should I modify to solve my problem? here's an extract of the snappyHexMEsh dictionary: Code:
addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes false; // was true con false hanno la stessa grandezza layers { wallAsp {nSurfaceLayers 15;} } expansionRatio 1.1; thickness 0.008; //firstLayerThickness 0.015; //was 0.00018 minThickness 0.001; nGrow 0; // was 1 // Advanced settings featureAngle 310; // When not to extrude surface. 0 is flat, 90 is right angle. // nRelaxIter 2; // Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 50; // Number of smoothing iterations of surface normals nSmoothNormals 3;//50 Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10;//100 Smooth layer thickness over surface patches maxFaceThicknessRatio 0.8; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.9;//0.9 Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 135 ; //135; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0;// Create buffer region for new layer terminations nLayerIter 20;//20 Overall max number of layer addition iterations nRelaxIter 20; //Controls number of scaling back iterations during error reduction stage } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls {/* maxNonOrtho 65; //180 maxBoundarySkewness 20; //-1 maxInternalSkewness 15; //-1 maxConcave 80; //180 minVol -1e33; minTetQuality -1e30; minTwist -1e30; minDeterminant -1; minFaceWeight -1; minVolRatio -1; minArea -1; minTriangleTwist -1;*/ maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; //80; minFlatness 0.5; minVol 1e-13; minTetQuality -1e30;//1e-9; // minArea -1; minTwist 0.02; //-1e30; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues | nathanricks | ANSYS Meshing & Geometry | 0 | September 23, 2015 05:14 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
