[cfMesh] How does cfMesh determine which region to mesh |
March 24, 2015, 02:28 |
BastiL
Rep Power: 20 |
Hello all,
I have a stl-File with multiple volume regions in. CfMesh warns me about non-manifoldness which is caused by the multi-regions present. However, it just meshes one of the regions - and an unimportant one. I want to have the choice which region to be meshed or to keep all regions and delete the unrequired once afterwards. Thanks for your hints. |
March 26, 2015, 11:27 |
... same here ....
Carsten Thorenz
Rep Power: 17 |
Hi Bastil,
I have the same request, as I quite often use STLs which form multiple "volumes", but I found no way in cartesianMesh to define a "region of interest" by a seed point or the like. Apart from that I think that cfmesh is really nice. It works much better than snappyHexMesh at difficult curved surfaces, IMHO. Best, Carsten |
March 27, 2015, 07:38 |
In the current form, cfMesh generates a mesh in a single domain. If there exist multiple disconnected parts, it will only keep the part with most cells and remove cells from the other ones. The warning "Surface is not a manifold" is just a warning that the topology of the surface mesh cannot be preserved in the volume mesh. The functionality to capture all domains is not in the official release. There is a branch feature-multiMaterial in the git repository containing some basic work towards multi-material meshing. It allows for using allowDisconnectedDomains 1 in meshDict, and the mesher then preserves the mesh inside all volumes and meshes them independently, and it does not ensure conformal connection between the domains. This serves as a temporary solution. I hope this helps. Regards, Franjo |
April 15, 2015, 09:52 |
amine
Rep Power: 12 |
Dear Franjo,
I have download and compiled a cfMesh-code to test the feature-multiMaterial by adding allowDisconnectedDomains 1 in my meshDict but it's doesn't work!!! Do I have something wrong with my approach? Thanks |
August 9, 2022, 04:40 |
#5 | |
Rep Power: 14 |
Hi Franjo
I have followed your solution to generate mesh independently. I'm wondering if we have a solution to build a conformal mesh up to now. Looking forward to hearing from you. Best Regards, Kit Quote:
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 02:23 |
[TurboGrid] Holes and overlap of Mesh elements in Shroud Region | vishwasvemra | ANSYS Meshing & Geometry | 0 | July 12, 2017 01:39 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
