Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
SHM error: inside mesh not possible
Old   April 9, 2015, 04:50
Default SHM error: inside mesh not possible
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi foamers,
I m new to sHM. I have room geometry with two person ,and a object on the floor . there are inlet,outlet and window on the room surface. stl files are generated from salome.
i guess i did everything right then i created blockmesh,surfaceFeatureExtract,decomposed for parallel computing everything worked,
now when i specify the snappyHexmesh it says an error: inside mesh not possible. probably the geometry is not closed. but when i reopened the geometry stl files in other software they look closed. and location of mesh is also correct.
Then i tried with out any mode in refinement regions .
refinementRegions{}
then the meshing was done but the cell removal did not work. that is the cells from block mesh are still there .
i tried all possible ways but i couldnt find a solution. could come body please help me . I m lost. am i missing some thing??
// Which of the steps to run
castellatedMesh true;    // make basic mesh ?
snap            true;    // decide to snap back to surface ?
addLayers       false;   // decide to add viscous layers ?
geometry // Load in STL files here
    inlet.stl {type triSurfaceMesh; name inlet;}
    outlet.stl {type triSurfaceMesh; name outlet;}
    heater.stl {type triSurfaceMesh; name heater;}
    roomwall.stl {type triSurfaceMesh; name roomwall;}
        roof.stl {type triSurfaceMesh; name roof;}
        floor.stl {type triSurfaceMesh; name floor;}
        window.stl {type triSurfaceMesh; name window;}
        table.stl {type triSurfaceMesh; name table;}
        man1.stl {type triSurfaceMesh; name man1;}
        man2.stl {type triSurfaceMesh; name man2;}
    mergedtest.stl {type triSurfaceMesh; name mergedtest;}
    //refinementBox {type searchableBox; min (-2 -2 6); max (7 5 -2);}
castellatedMeshControls
    maxLocalCells 3000000;  //max cells per CPU core
    maxGlobalCells 16000000; //max cells to use before mesh deletion step
    minRefinementCells 50;  //was 0 - zero means no bad cells are allowed during refinement stages
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;  // expansion factor between each high & low refinement zone
    // Explicit feature edge refinement
    features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
        {file "inlet.eMesh"; level 0;}
        {file "outlet.eMesh"; level 0;}
        {file "roomwall.eMesh"; level 0;}
        {file "heater.eMesh"; level 3;}
        {file "roof.eMesh"; level 0;}
        {file "floor.eMesh"; level 0;}
        {file "window.eMesh"; level 0;}
        {file "table.eMesh"; level 0;}
        {file "man1.eMesh"; level 3;}
        {file "man2.eMesh"; level 3;}
        //{file "mergedfull.eMesh"; level 3;}
    // Surface based refinement
    refinementSurfaces // Surface-wise min and max refinement level
    inlet {
        level (0 0);//faceZone inlet;cellZone inlet;cellZoneInside inside;
        } // was 0 0
        outlet1 {
         level (0 0);//faceZone outlet;cellZone outlet;cellZoneInside inside;
    roomwall {
        level (0 0);//faceZone roomwall;cellZone roomwall;cellZoneInside inside;
        }  //was 3 3
    heater {
        level (1 2);//faceZone heater;cellZone heater;cellZoneInside inside;
        } // was 4 4
        roof {
        level (0 0);///faceZone roof;cellZone roof;cellZoneInside inside;
        floor {
        level (0 0);//faceZone floor;cellZone floor;cellZoneInside inside;
        window {
        level (0 0);//faceZone window;cellZone window;cellZoneInside inside;
        table {
        level (0 0);//faceZone table;cellZone table;cellZoneInside inside;
        man1 {
        level (1 2);//faceZone man1;cellZone man1;cellZoneInside inside;
        man2 {
        level (1 2);//faceZone  man2;cellZone man2;cellZoneInside inside;
        mergedtest {level (2 2);}
    resolveFeatureAngle 80;  // (before 80) .Resolve sharp angles // Default 30
    refinementRegions        // In descending levels of fine-ness
    {mergedtest {mode inside;levels ((0.3 3));}}
     //{mode distance; levels ((0.01 4) (0.3 3) (1 2));}} // was ((0.001 4) (0.003 3) (0.01 2))
    locationInMesh (1 2 1);  //to decide which side of mesh to keep **
    allowFreeStandingZoneFaces false; // before true
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
    nFeatureSnapIter 15; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces
// Settings for the layer addition.
addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName
    relativeSizes false; // was true
    layers
    visc_main
             {nSurfaceLayers 3;} // was 3
    visc_refine_1
    visc_refine_2
    expansionRatio 1.3;
    finalLayerThickness 0.00016; //was 0.00016
    minThickness 0.00008; //was 0.00008
    nGrow 0; // was 1
    // Advanced settings
    featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle.
    nRelaxIter 3;  //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
    nSmoothSurfaceNormals 1;  // Number of smoothing iterations of surface normals
    nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction
    nSmoothThickness 10;  // Smooth layer thickness over surface patches
    maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells
    maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large
    minMedianAxisAngle 130;  // Angle used to pick up medial axis points
    nBufferCellsNoExtrude 0;   // Create buffer region for new layer terminations
    nLayerIter 50; // Overall max number of layer addition iterations
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minTetQuality 1e-9;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    // Advanced
    nSmoothScale 4;
    errorReduction 0.75;
// Advanced
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Thank you
regards,
Naresh
Naresh yathuru is offline   Reply With Quote
Thread Tools
Trackbacks are On
problems generating clean mesh Christian_tt OpenFOAM Native Meshers: snappyHexMesh and Others 0 May 16, 2014 10:58
Problems with multi-region mesh in sHM Artur OpenFOAM Meshing & Mesh Conversion 0 July 16, 2013 08:52
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 39 June 5, 2013 19:02
Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Native Meshers: snappyHexMesh and Others 8 September 13, 2012 09:28
Mesh becoming coarser during addLayers in sHM Arnoldinho OpenFOAM Native Meshers: snappyHexMesh and Others 4 April 6, 2011 12:20
