[snappyHexMesh] snappyHexmesh: "Your current settings specify ASCII writing with 6 digits precision." |
June 29, 2015, 11:10 |
Ron de Vos
Rep Power: 10 |
I do wigleyHull tutrioal I get the following when i fille in snappyHexMesh I don't understand
--> FOAM FATAL ERROR: Your current settings specify ASCII writing with 6 digits precision. Your merging tolerance (1e-006) is finer than this. Change to binary writeFormat, or increase the writePrecision or adjust the merge tolerance (mergeTol). From function getMergeDistance(const polyMesh&, const dictionary&) in file snappyHexMesh.C at line 558. can perhaps anybody say what I do wrong |
July 2, 2015, 07:32 |
Rep Power: 11 |
Set the write precission in your controlDict file to at least 1e-07 as it is said in the error massage. Or decrease the mergeTol in your sHM dict
July 2, 2015, 10:56 |
Ron de Vos
Rep Power: 10 |
I have decreased MergeTol and yes
thank you |
July 21, 2015, 15:11 |
p-rgh
Ron de Vos
Rep Power: 10 |
I work on wigley Hull.
What will I do with p-rgh I allready tryed everything --> FOAM FATAL IO ERROR: Illegal dictionary entry or environment variable name "p_rgh" Valid dictionary entries are 0() file: C:/OpenFOAM2/cygwin64/home/Windschip/OpenFOAM/OpenFOAM-2.2.x/tutorials/multiphase/LTSInterFoam/wigleytestc/system/fvSolution From function primitiveEntry::expandVariable(const string&, const dictionary& in file db/dictionary/primitiveEntry/primitiveEntry.C at line 96. FOAM exiting thank you in advance Ron |
January 29, 2018, 08:03 |
Avik Saha
January 29, 2018, 08:31 |
Rep Power: 8 |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
Precision error when running snappyHexMesh | SirLankyIII | OpenFOAM Pre-Processing | 0 | July 15, 2014 02:17 |
