I should like group and rename patches AFTER meshing
Hi to everybody.
I did a long session, that should have terminated with grouping together all patches like "pareti.*" and rename the resulting single patch simply "pareti" (in Italian, pareti means walls). Anything goes well, but patches are not grouped and not renamed. There is an utility able to do this job AFTER meshing process? I ask this because the whole meshing process take more then a couple of hours . . . Thank you in advance Piero |
Many thanks Piero |
cfMesh: renameBoundary option
I hope that your problems are resolved by removing an extra }. Currently, it is not possible to rename boundary patches because it is not implemented as a separate utility. It is not difficult to do, all you need is to create a new utility and copy the code for renaming boundaries from cartesianMeshGenerator.C. How many cells are there in the case lasting a couple of hours and how many cores were available for the meshing job? Ciao, Franjo |
About the size of the problem, the final mesh has about 7.5 Million Cells; the hardware is a little obsolete: 2xAMD Opteron 2222 (totale 4 cores), 16 GB memory, but only DDR2 at 666 MHz. Actually I see a decisive increment in performances: only 12 minutes to calculate about 10 Million Cells. Perhaps I'm now more experienced :D (the hw is still the same) . . . . Ciao e grazie Piero |
