snappyHexMesh - geometry does not appear in Mesh
1 Attachment(s)
Hi, I am new to this and having problems to form a mesh with a geometry inside the mesh domain. My geometry is a cylinder of diameter 0.06m, height of 1m. My domain is 2.5m(L) x 1.5m(W) x 1m(H). Cylinder is located in dead center of the domain box. Attached is a rough sketch.
Below are my blockMeshDict and snappyHexMeshDict. I've ran surfaceCheck on my STL and there is no problem with that. Quote:
hey,
I have the same problem as you before. I have already solved it. as my experiences, perhaps you can try to create a big enough block in your blockHexMeshDict. or: make sure that your geometry in the .stl file and the block from the blockHexMeshDict are in the same direction in your coordinate and they have the same unit. regards, Cheng |
