[snappyHexMesh] SnappyHexMesh development?
Like Tree1Likes
  • 1 Post By Tobi
Old   November 2, 2015, 09:56
Default SnappyHexMesh development?
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
does anybody know if snappyHexMesh will be developed further (like improvements that are done within the version of engys?)
I am asking because the last updates does not contain any changes to the meshing application.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   November 2, 2015, 16:06
Retired Super Moderator
Bruno Santos
Quick answer:
The developments made by OpenCFD are available to be integrated into OpenFOAM-dev, but it cannot be simply copy-pasted from one version to the other. The two development lines were most of the time made separately, so in the History repository that was made available on the 22nd of October seems to include all of the work that OpenCFD made internally since 2008. There are several work-in-progress features in the History repository that still need to be tested, diagnosed and finished.
As for when this transfer will be done... AFAIK it's pending sponsorship and/or volunteers.
Old   November 2, 2015, 16:54
Tobi's Avatar
Tobias Holzmann
Hi Bruno,
still you are acting like a machine in this forum....
Thanks for the replay. I would also investigate into the meshing topic but there are so man y other things to do. At least still programming flamelet during my spare time ...
Kind regards
Tobi
wyldckat likes this.
Keep foaming,
Tobias Holzmann
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
