[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh |
November 21, 2015, 13:57 |
Lorenzo
Rep Power: 10 |
Hi everyone,
I'm rather new to openFoam and its utilities like snappyHexMesh and I faced a problem in setting up the proper information in the snappy-subdictionary refinement Region. I have to mesh an airfoil given in stl and my background mesh is realized by blockMesh using a 0.1 conversion to meter (so dm ) . If in the snappy subdict refinement Region I set distance (0.025 5) does it mean that below 0.025 dm from my stl the refinement level is 5?more precisely does 0.025 refer to the unit conversion set in the blockMeshDict (0.1 in this case)? Thanks in advance |
[snappyHexMesh] Problem with decomposePar, snappyHexMesh | luca1992 | OpenFOAM Meshing & Mesh Conversion | 12 | August 23, 2017 19:06 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 14:46 |
[snappyHexMesh] Running SnappyHexMesh - problem with refinement | DOliveira | OpenFOAM Meshing & Mesh Conversion | 0 | April 28, 2015 05:22 |
[snappyHexMesh] SnappyHexMesh, meshing problem with multiple stl's | knarftrebron | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2015 08:19 |
[snappyHexMesh] snappyHexMesh - problem using *.obj file | inf.vish | OpenFOAM Meshing & Mesh Conversion | 4 | October 7, 2013 03:54 |
