February 7, 2016, 11:51 |
Gambit to foam
Fatemeh
Rep Power: 10 |
Hi every one. I want to export a 3d mesh from gambit to foam. Would anyone please tell me if I need the blockMeshDict file any more? Thanks
March 12, 2016, 10:56 |
Artur
Rep Power: 19 |
blockMeshDict is only needed if you're going to run blockMesh on the case, if you are using an external meshing tool you may safely remove it. A |
March 13, 2016, 02:16 |
Fatemeh
Rep Power: 10 |
Thanks so much for your help
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[Commercial meshers] gambit mesh to Foam problem | AmirBaqa1987 | OpenFOAM Meshing & Mesh Conversion | 1 | May 19, 2013 05:26 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 22:50 |
