[snappyHexMesh] Isn't the "concave cells" really wrong? |
March 3, 2016, 02:25 |
Rep Power: 10 |
Dear Sir,
I have used snappyHexMesh for the first time, and "checkMesh" is OK. But, when I calculate simpleFoam solver using the generated mesh, velocity U rapidly decreases close on inlet (lower side of geometry), where there is no resistance such as porous. (see the attached picture1). When I did "checkMesh -allTopology -allGeometry", I found concave cells error. (see the attached picture2 & 3, in which red color represents the concave cells.) Do concave cells cause this U decrease? On the other hand, I found some articles which say "don't have to worry about concave cells". (for example, https://www.researchgate.net/post/Op...ve_Mesh_Error2) My question is that, don't we really have to worry about concave cells? If we should worry about this, how can we deal with? If don't have to, do you think why U rapidly decreases? I am looking forward to your advice and comment. Sincerely, KeiJun |
March 3, 2016, 03:31 |
Anton Kidess
Rep Power: 29 |
http://www.cfd-online.com/Forums/ope...tml#post537935
http://www.cfd-online.com/Forums/ope...tml#post191366
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
March 3, 2016, 03:59 |
Rep Power: 10 |
Thank you for your reply.
They are very helpful information. But then, do you think why does U decrease close to the inlet? KeiJun |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
Fluent UDF wrong number of cells in parallel - correct in serial | dralexpe | Fluent UDF and Scheme Programming | 7 | May 17, 2018 08:26 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Is there a built in way to fix concave cells? | richard_vega | OpenFOAM Meshing & Mesh Conversion | 0 | August 18, 2015 14:12 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
