[snappyHexMesh] SHM - Change tolerance to deal with gaps in CAD geom |
March 20, 2016, 17:58 |
Lisandro Maders
Rep Power: 13 |
I have a geometry which has some gap in the CAD, but I am not able to edit this. Is there any way to change tolerance in snappyHexMesh in order to make such gaps invisible to the mesh generator? The problem is that I have fluid inside this geometry, and I should not. The figure shows the geometry. In the top, it was well recognized, but the bottom part of the engine it was meshed inside it.. Best regards, Lisandro |
March 21, 2016, 04:11 |
Rep Power: 15 |
I would have thought it would be better to repair the STL using something like the MeshLab: http://meshlab.sourceforge.net/
Then use surfaceConvert function to clean your stl and see that its good for use. |
gap, snappyhexmesh, tolerance, tolerance change |
[snappyHexMesh] surfaceAutoPatch generate internal faces so SHM doesnot read the whole CAD | rsa | OpenFOAM Meshing & Mesh Conversion | 0 | March 7, 2019 07:03 |
[CAD formats] CAD export for SHM | plucas | OpenFOAM Meshing & Mesh Conversion | 0 | January 17, 2019 10:43 |
CHT-Problem: Gaps and intersections in CAD | Zhudasch | ANSA | 1 | October 23, 2017 08:32 |
Importing CAD geometry and Editing edges to match | Ahmed | CFX | 15 | March 21, 2016 12:39 |
which program in phoenics can change CAD file | Xyj | Phoenics | 4 | May 29, 2001 06:48 |
